CHEVROLET CAPTIVA ACTIVO 2020
Automatic analyzing the cylinder pressure waveform
Andres Chavez
Post by Andres Chavez » Sun Jan 10, 2021 11:36 pm
EL MOTOR FUNCIONA BIEN PERO AL MOMENTO DE HACERLE LA PRUEBA DE PRESION DENTRO DEL CILINDRO. LA CURVA MANIFIESTA QUE LA VALVULA DE ESCAPE SE CIERRA ANTES DE TIEMPO. EL MOTOR CUENTA CON DISTRIBUCION VARIALE.
CILINDRO 1.psdata
(437.89 KiB) Downloaded 1522 times
Re: CHEVROLET CAPTIVA ACTIVO 2020
Post by admin » Tue Jan 12, 2021 7:43 am
Unfortunately, your waveform was recorded using PicoScope 7 software.
In this version the ability to export waveform files to MATLAB format is blocked.
You can save this file to an older version PicoScope 6 software and upload again.
