Injectors Raster mode
Post by admin » Tue Oct 13, 2020 11:31 am
In modern engine management systems, the control pulses for gasoline injectors are spaced in time.
Because of this, it can be difficult to compare their shape and duration.
Mode called Injectors_Raster.upc is designed to work with time-separated signals coming to different channels of the oscilloscope.
This mode displays pulses in the form of a raster, which allows to compare visually their shape and duration.
Injectors Toyota Corolla 1.6 2019.png (2.4 MiB) Viewed 37816 times
You can download a ready-made configuration file here
(853 Bytes) Downloaded 1161 times
pauloirogerio
Re: Injectors Raster mode
Post by pauloirogerio » Fri Oct 16, 2020 5:50 pm
very good, I could do it in the ignition primary :mrgreen: :mrgreen:
https://SecreLocal.com - Video Chat Dating - No Verify - Anonymous Adult Dating - Live Video Chat
Post by admin » Tue Oct 20, 2020 8:53 am
Yes, you can do it with the ignition primary
Adelson Maurício
Post by Adelson Maurício » Sun Oct 25, 2020 9:47 pm
Se usar o modo injector Raster na ignição primária pode queimar a entreda do USB autoscope?
Post by admin » Thu Oct 29, 2020 12:55 pm
No, but the signal will be limited to 30V.
Post by Pablo Caballero » Sat Oct 31, 2020 6:35 pm
Muchas gracias! Muy útil!
Y por cierto quiero agradecer por el script que hicieron llamado "SignalDAFP".
Sumamente preciso y eficaz!
Habrá posibilidades que en algún momento se pueda por ejemplo agregar medidas o "measure" para podes ver medidas en tiempo real de cada canal tanto en el eje vertical de voltaje como el eje horizontal de tiempo?
Post by Pablo Caballero » Sat Apr 09, 2022 3:40 pm
[/quote]
Hello! How do we load the mod?
Post by Pablo Caballero » Sat Apr 09, 2022 3:52 pm
Post by Pablo Caballero » Sat Apr 09, 2022 4:39 pm
Hello Diogo! I have an adapter to Pin3/Bnc and i use the cable of laboratory scopes 10:1. And Change settings
Pin3- bnc Adapter e.jpg (52.63 KiB) Viewed 9851 times
minakshi
Contact:
Post by minakshi » Wed Dec 25, 2024 12:36 pm
Can Injectors Raster mode be used effectively with other types of signals, like diesel injectors? Also, is there a guide for setting it up for beginners?
